Kaufberatung
Verfasst: 03.06.2005 - 18:37
von daa998
Hallo wer kann mir was zu diesem Teil sagen:
GPS Kompass Navibacksystem
Spezifikationen
- Channel : 12 parallel channel GPS receiver continuously tracks
and uses up to 12 satellites to compute and update your position
- Main power input : AAA x 2 - Battery life : 15 to 20 hours, typical use
- Acquisition times
* Cold : 50 sec., typical TTFF
* Warm : 35 sec., typical TTFF
* Hot : 8 sec., typical TTFF
- Waymarks : 500
- Trips / Waymarks per trip : 20/125
- Routes : 10 saved routes and 10000 routepoints
- Update rate : 1 sec.
- Alarms : N/A
- GPS Accuracy
- Trip Computer : One seperate table shows related speed,
* Position : 3~5 m without S/A direction, and distance information
* Velocity : 0.1m/sec without S/A
- Map datums : More than 80
- DGPS (WAAS) Accuracy
* Position : 3m
- Electronic Compass Features:
- Accuracy : +/- 3 degree
- Resolution : +/- 1 degree
* Velocity : max. 500m/sec
* Altitude : max. 18000m
* Acceleration : +/- 4g -
- Resolution : 1m
- Physical Characteristics
- Case : Watreproof to IEC 529 IPx7 standards
- Elevation computer : Related elevation information
- Size : 122.6(L)x76(W)x37.4(H)mm / 4.83"Lx2.99"Wx1.47"H
- Pressure : Local pressure (mbar/inches HG) 12-hour automatic
- Weight : 90g with batteries pressure trend recording
- Display : 50.51(L)x28.86(W)mm / 1.99"Lx1.14"W, 64 x 120
pixels high contrast, bright LED backlighting
- Environment Conditions
- Antenna : Built-in patch antenna
- Operating Temperature Range : -20 ~ +70 Centigrade
- Interface connect to PC : RS-232 / NMEA 0183
- Storage Temperature Range : -30 ~ +80 Centigrade
- Humidity : 5% ~ 95%
Danke
Gerhard
Schnittstelle?
Verfasst: 06.06.2005 - 20:07
von Prizo
Hallo da99,m
was kann die PC-Schnittstelle noch? Sollte die tatsächlich nur NMEA unterstützen, so kann man Routen, Tracks&Punkte weder ins Gerät rein- noch aus'm Gerät rausladen. Für ein Gerät ohne Basemap (oder gar Routing-Funktion) m.E. ein K.O.-Kriterium, da es dann nur geringfügig mehr Nutzen hat als eine GPS-Maus.
Was das Gewicht mit der Luftdruckaufzeichnung zu tun hat, weiss ich nicht ;-) und ob da jetzt ein Fluxgate-Kompass drin ist oder die Himmelsrichtung aus GPS&Bewegung gewonnen wird, hab' ich nicht verstanden. Ansonsten sind das die üblichen Daten eines Nicht-Map-fähigen Einsteiger-Gerätes, vgl. Geko/Forerunner 201/301. Wobei damit noch nichts über die Empfangsqualität ausgesagt ist und wie nützlich das Gerät tatsächlich ist, sprich: Was man mit den vorhandenen (z.B.) Tracks anfangen kann. Bye.
