RTKLIB auf Android-Geräten
Re: RTKLIB auf Android-Geräten
Beitragvon gto234 » 02.06.2016 - 17:58
Hagen.Felix hat geschrieben:
gto234 hat geschrieben:... forwarding the output solution to TCP Server ...
That's the best way, IMHO ... :wink:
Yes it works pretty good!
For whom may interest the android app I used to forward the NMEA message from TCP Client to Bluetooth SPP is called "GetBlue Data Acquisition Tool" and it was the only one that could make this happen.
One more question.
Do you find better mode for kinematic the Continuous or Fix-and-Hold method?
The fix-and-hold works good but I don't know if the accuracy is good because it holds the fix with very little satellites.
In the other hand the continuous method is somehow unstable because it fixes pretty quick at start and then if the receiver loses the signal it delays a lot to fix again.
What do you think?
gto234
Beitragvon Hagen.Felix » 02.06.2016 - 20:37
gto234 hat geschrieben:... the android app I used to forward the NMEA message from TCP Client to Bluetooth SPP is called "GetBlue Data Acquisition Tool" and it was the only one that could make this happen.
Even Android is only "second choice" mobile device OS for my daily work, this was one of the first paid apps that I installed ... :mrgreen:
Developer website: http://www.tec-it.com/de/software/andro ... fault.aspx
As already quite often discussed in this forum, "Fix & Hold" isn't any good way with our L1 only receivers.
Usually the "Continuous" option should be preferred, and it could be very useful to get this additional benefit:
https://rtklibexplorer.wordpress.com/
resp.
viewtopic.php?f=4&t=3634
resp.
https://github.com/rtklibexplorer/RTKLIB/
Beitragvon gto234 » 06.06.2016 - 09:22
Thanks for the links, they are very useful.
I now understand why I see this behavior. At first it fixes very fast, then after a while it looses the fix and reverts to float and stays there. So it is a bug of rtklib.
I will try different settings suggested from the links you sent to see if I have better results.
gto234
Beitragvon Hagen.Felix » 18.07.2016 - 13:59
Hagen.Felix hat geschrieben:Dinu Berca im Arbeitseifer ... :mrgreen:
Da jetzt gerade mal wieder am Thema dran, siehe da ... :mrgreen:
https://rtklibexplorer.wordpress.com/2016/02/26/improving-rtklib-solution-ar-lock-count-and-elevation-mask/comment-page-1/#comment-131
June 21, 2016 at 11:56 pm
Dinu says:
Hi
You can download the fresh RTKGPS+ builds of from here:
https://mega.nz/#!9wtgCKBI!tfD7neNLF2Bcp7BPm3XRcX0mwMhEb-a6Fi2H8E1ZvCY (2.4.2 P11 ARM&X86)
or from here:
https://mega.nz/#!8tkEjSJb!50lCbV0XPBP5Swo26V2wWleszYDjQHdvR1AGG_Nknfk (2.4.3 b12 X86 only)
Beitragvon spunky » 21.08.2016 - 10:54
ich bekomme keine Verbindung zur TCP Ausgabe von RTKGPS+ (z.B. localhost:1234), kann das jemand bestätigen?
TCP von RTKnavi vom PC zu Android geht.
auch bei der Ausgabe im allgemeinen stimmt was überhaupt nicht, da bekomme ich extreme Abweichungen innerhalb von wenigen Sekunden:
stürtzt auch regelmäßig ab und startet neu.
Beitragvon RandyFO » 17.02.2017 - 12:20
Ich habe vor kurzem auf der Suche nach einem Keylogger für Android, sagen Sie mir, wo ich so etwas finden kann. Ich fand eine Menge Software für den PC, übrigens, die hier interessiert sind, ist eines der besten meiner Meinung nach https://de.refog.com/. Es funktioniert gut und ohne zusätzliche Belastung auf den Prozessor.
RandyFO
Vorherige
Zurück zu GPS und Software
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 5 Gäste
cron
